OEM replacement bulbs for gauge cluster
I can't find any info on the board, does anyone have any ideas? There are 13 "74" bulbs in the integra 94+ gauge cluster, the bulbs at all of the local auto parts stores are Sylvania bulbs and are very fat, therefore they fall out of the socket after a few days because they don't seat properly. There must be another brand out there that is a compatible fit. Any suggestions?
What bulbs are you trying to replace? If you're replacing the main bulbs that light up the speedo/tach/etc... just look for the bulbs that say "194" on the package and they'll fit and work. If you're looking for the little bulbs that light up the oil light, cel light, etc, then i'm not sure.
^ Yeah... it IS alot just for bulbs... I did a quick search on google, and even other online stores will add up to around $40ish if you need to replace all 13 bulbs. =/
edit: Best I've found is on amazon.com...
http://www.amazon.com/74-10-Automoti...925018&sr=8-38
^ 10 pack for $5.15
http://www.amazon.com/Lighting-Autom...3924949&sr=8-2
^ 2 pack for $1.95
^Pretty sure these are the right ones.
^ 10 pack for $5.15
^ 2 pack for $1.95
PhatBoiOnDiet
Jan 27, 2013 07:02 PM
crazydragonclk
Jan 25, 2006 10:11 AM
