Problem with H22, wont go past 3000 RPM
Old Sep 24, 2009 | 09:26 AM
krazieV's Avatar
Icon7 Problem with H22, wont go past 3000 RPM
I dont know what is up with the engine but it wont let me go past 3000 rpm. When I go past 3000 RPM, the car wont go anymore even when I had the peddle down the car still wont go and I go into 2nd gear the car will still go but only to 2000 RPM. I really need help. Need the car to be driven.
Old Sep 24, 2009 | 12:27 PM
Quan_97SH's Avatar
Default Re: Problem with H22, wont go past 3000 RPM
any cel code?
Old Sep 24, 2009 | 12:45 PM
JohnM10's Avatar
New User
How does the engine sound? Can you rev the engine past 3000 rpms in neutral?
Old Sep 24, 2009 | 02:00 PM
mxmaniacx250's Avatar
was any work recently done. check and make sure the map and the tpe plugs werent reversed
Old Sep 24, 2009 | 04:47 PM
Janet@bisimoto's Avatar
x2. You should try this and post your results.
Old Sep 24, 2009 | 08:23 PM
krazieV's Avatar
Originally Posted by Quan_97SH
any cel code?
There isn't any check light engine if that is what you mean.
Old Sep 24, 2009 | 08:30 PM
mafia's Avatar
I have same problem but it dont wana go past 6k and bloggs no cel. on hondata S300. car is power less 90% of time, tired of changing stuff still dont wana run right. ....
sorry dont mean to thred jack but it seems we have simmiler problem.
Old Sep 24, 2009 | 08:36 PM
krazieV's Avatar
the engine sound normal when i start it up but when the engine start to warm up then it sound like harley davidson and yes i can rev it past 3000 rpm in neutral. only when i am in gear. in gear 1 i can only go to 3000rpm and in 2 gear only 2000rpm
Old Sep 26, 2009 | 05:42 PM
krazieV's Avatar
thanks to all who try to help me out i appreciate it alot.. but i have solde the problem it was the tps it was broken so i replace it and it work.
THANK
Old Oct 27, 2020 | 11:55 AM
Matt Fliegel's Avatar
Had this problem for weeks replaced distributor and put a ground wire from battery to chasis problem solved.
OnceIwasMuffin
May 18, 2015 02:17 AM
Freeman1017
Aug 26, 2008 06:38 AM
KOVENANT
Oct 4, 2004 01:09 AM
TriCkSpEeD
Jul 24, 2001 12:35 PM
