clutch slipping
Old Sep 24, 2009 | 08:06 AM
twistedgsr's Avatar
Default clutch slipping
i have a 94 gsr my clutch started slipin a couple of months ago and now it is so bad i can hardly take off high rpms is ok low rpm just slips someone told me that oil is leaking on the clutch. i have a new 6 puck but want to fix the problem first
Old Sep 24, 2009 | 08:32 AM
dothacker's Avatar
Default Re: clutch slipping
if you have a slipping clutch, there should only be one fix for that... replacing it. when you replace it and you see oil in it, then trace where it's coming from.
Old Sep 24, 2009 | 09:02 AM
Dr. Will Race's Avatar
could be your rear main seal
Old Sep 24, 2009 | 09:35 AM
twistedgsr's Avatar
i have a new clutch but it goes into gear fine never grinds so i know it has to be something else causing it to slip i just want to know what i have to do to fix the problem before i get into it dont want to ruin a new six puck clutch
Old Sep 24, 2009 | 09:42 AM
1grex's Avatar
It is your rear main seal
Old Sep 24, 2009 | 09:47 AM
dothacker's Avatar
see you didn't say you have THE clutch installed on the car. like what they said, it's your rear seal.
Old Sep 25, 2009 | 05:21 AM
twistedgsr's Avatar
sorry for the confusion i have not installed the clutch yet but i get it the rear main thanks now i just got ton fix it
EgHatchy96
16
Jul 6, 2013 05:12 AM
insaneshoota
Jul 10, 2007 04:19 PM
JDM_COUPE94
Feb 24, 2007 09:34 AM
climbengruven
Dec 29, 2005 11:06 AM
Flexer
Apr 16, 2004 07:43 AM
