changed rear calipers brake light is on
Old Sep 23, 2009 | 06:55 AM
OBDII Integra's Avatar
Default changed rear calipers brake light is on
I replaced my old calipers wit some new ones and did the front and rear while i was at it, bled the brakes, fluid in the resovoir is good, but now when i put down my ebrake down the light stays on, its def still not engaged, and the light wasnt on before i changed it, could this be that the switch is going bad?, where would this be located? Thanks
Old Sep 23, 2009 | 07:00 AM
HONDRETTI's Avatar
Default Re: changed rear calipers brake light is on
this happened in my old DA and i eventually got used to the light being on.
try adjusting the cable, the adjuster is located within the cable under the e brake boot.
Old Sep 23, 2009 | 07:04 AM
i'll have to try that, thankss
Old Sep 23, 2009 | 09:22 AM
Spawne32's Avatar
i know there is also a contact sensor right next to the ebrake handle that controls that light as well
Old Sep 23, 2009 | 09:32 AM
bigislandc2's Avatar
also check the brake fluid level..
1cool87Civic
Classic Hondas
Feb 13, 2012 09:11 PM
Type ARRR
Jun 22, 2011 04:48 PM
JDM_SOHC
12
Nov 29, 2005 06:01 AM
zerogravitycrx
Apr 6, 2005 11:29 PM
Rguy
Aug 7, 2002 05:12 AM
