Gauge Cluster issues
Old Sep 23, 2009 | 01:10 AM
xsicrx120's Avatar
New User
Default Gauge Cluster issues
I have a 89 crx with a xsi b16a swap in it, i had the car parked after putting the motor in it and only put about 4k on the motor(everything was working properly) and i let it sit in my garage for about a year and a half and i recently started driving it again and my temp gauge isnt working my fuel gauge isnt working and the tach isnt working also along with my blinkers and the only light that comes on when starting my car is the battery light...I have tested all my fuses under my dash and under my hood and there all fine....I am stuck and dont kno what the problem is and need some help
Thanks
Old Sep 23, 2009 | 01:24 PM
xsicrx120's Avatar
New User
Default Re: Gauge Cluster issues
any help would be great
Old Sep 23, 2009 | 02:00 PM
Briangzm's Avatar
It seems something has gone wrong in your gauge cluster. Ill say you visually check it from the rear,maybe a loose connection. I really doubt you have the temp sensor, fuel sending unit and tach bad at the same time. One thing i can tell you is that the temp and fuel gauges work with a magnetic coil inside the gauge cluster. Thats where i would look first...
aznnikeballer887
May 5, 2008 11:08 PM
compprat
May 11, 2006 11:14 PM
myronwong
Nov 14, 2005 09:13 PM
96_GSR
Mar 22, 2003 06:05 AM
Erik_Pb_Foot
Apr 26, 2002 09:05 PM
