mini me help
Old Sep 22, 2009 | 04:58 PM
nitewolf's Avatar
Default mini me help
freinds car is only running on cylnder 3 and 4. 90 dx. mpfi swap.
all plugs are sparking. the spark plugs are wet with gas. i dont kno what the problem could be
Old Sep 22, 2009 | 05:18 PM
4drEF's Avatar
Keyboard Humorist
Default Re: mini me help
Firing order correct for your plug wires?
Double check distributor wiring.
Old Sep 22, 2009 | 05:19 PM
mother ef-er's Avatar
sounds like firing order is off.
Old Sep 22, 2009 | 09:08 PM
nitewolf's Avatar
yea i think its the fireing order also. but the fireing order is correct. new plugs and wires... will checc the dizzy wireing. any more sugestions
Old Sep 22, 2009 | 09:16 PM
sleepingciv's Avatar
chipped or bent valves
Old Sep 22, 2009 | 09:41 PM
.Manny.'s Avatar
Touching My Member
did you just do the dpfi to mpfi conversion?
Old Sep 22, 2009 | 09:44 PM
nitewolf's Avatar
the valves looked good before the head went on the blocc
nitewolf's Avatar
yes
Old Sep 30, 2009 | 07:20 AM
apekd's Avatar
did you check the Injector wiring? pull the injector plugs off the injector, and then make sure there is power, if so then make sure that you have it wired up to the ECU properly so the ECU is grounding the injector so it sprays.
civicxxman
Apr 27, 2008 01:52 PM
psegs80
Jul 29, 2005 02:32 PM
crxhybrid1320
May 29, 2003 07:22 PM
EF'n
May 22, 2003 10:16 AM
