d16z6 turbo... wont start need help asap pleazz!!
Old Sep 22, 2009 | 04:55 PM
aaronpark's Avatar
Default d16z6 turbo... wont start need help asap pleazz!!
Just swapped d16z6 with turbo everythin is installed and hooked up. I started the car it ran for about 3 min till it warmed up. then died.. and now wont start. any suggestions??
Old Sep 22, 2009 | 07:10 PM
aaronpark's Avatar
Default Re: d16z6 turbo... wont start need help asap pleazz!!
not gettin any spark anymore.. changed cap and rotor still no spark. distr. bad?? doesnt make sense ran till it warmed up now nothin.. any reasons why im still not gettin spark?
Old Sep 22, 2009 | 07:26 PM
Former User's Avatar
Any CEL codes?
With the key in ON(II), is there battery voltage on the Blk/Yel wire attached to the coil and igniter unit in the distributor? If so, test the coil and igniter unit.
Old Sep 22, 2009 | 07:28 PM
rotasol's Avatar
Common issue with Hondas running, than immediately going to a no-start, is the ICM inside the dizzy. Ron is on the right path.
That's where I would look first.
Old Sep 24, 2009 | 09:49 AM
aaronpark's Avatar
Thats what i checked yesterday and that was it ignition module and i just went ahead and changed out the coil too. started right up. thanks.
Old Sep 25, 2009 | 04:21 PM
rotasol's Avatar
Glad you got it going.
sambaEG2
Mar 28, 2013 05:20 PM
92d15b7
Feb 23, 2011 10:55 AM
tundra2000
Jun 8, 2010 03:27 PM
turbodtaylor
Dec 14, 2009 12:16 AM
93civicproject
Jul 27, 2004 06:26 PM
