ls/vtec swap 97 civic- very low idle , bogging, barely stays running!! help asap!!!!!
Old Sep 22, 2009 | 03:13 PM
gotboosthatch's Avatar
Default ls/vtec swap 97 civic- very low idle , bogging, barely stays running!! help asap!!!!!
fixed it
Old Sep 22, 2009 | 04:17 PM
Default Re: ls/vtec swap 97 civic- very low idle , bogging, barely stays running!! help asap!
help
Old Sep 22, 2009 | 07:07 PM
Katman's Avatar
sounds like your engine has the claps! haha jfwy..
You may have your ignition wires mixed up on the dizzy. See if they're setup like this:
if its not that, are you getting any CEL's? if so, what are they?
What ecu are you using? OBD2 or converted to OBD1?
Old Sep 22, 2009 | 08:10 PM
firing order is right,
throwing the vtec code 21 and o2 sensor code 41 thats it..
obd1 p28 chipped from phearable
Old Sep 22, 2009 | 10:07 PM
bump help
Old Sep 23, 2009 | 08:42 AM
anyone?
Old Sep 23, 2009 | 09:43 AM
now throwing code 16 fuel inj?
Old Sep 23, 2009 | 10:23 AM
93egSLEEPER's Avatar
throwing a O2 sensor code will make your car run like crap alone. usually when that is screwed up, it causes a chain reaction and starts throwing other codes like it is now because the ecu is trying to compensate for th O2 sensor reading incorrectly. also sounds like timing might be off, of the timing belt is retarted a tooth
Old Sep 23, 2009 | 11:32 AM
timing is perfect it was in my integra running then I sold that shell and swapped it into the civic..
Old Sep 23, 2009 | 04:56 PM
help
Old Sep 23, 2009 | 05:28 PM
Clur's Avatar
K.. i noticed you used the OBD2 injectors.. what are they off of? I just did same swap and accidentally used DX injectors.. it ran like utter crap had no power @ all and i live in 5000+ elevation.. only way i could get from a to b was to tap throttle.. I changed all the sensors... spark plugs, wires.. adjusted the TPS again... so I'd try different injectors if I was you and also make sure you get rid of those CEL's the ELD is a pain sometimes to find.. but then again your sensor that is giving you problems may be the culprit..
Old Sep 24, 2009 | 09:55 AM
wondering how to fix the code 16 :/
Old Sep 25, 2009 | 11:05 AM
checked the tps voltage its good, checked for vac leaks -none, took injectors out and sprayed a box to check spray they r good, new plugs, new dizzy, checked battery voltage -good, reset ecu... and its still doing the same thing :/
Hatch_kyle
Apr 14, 2012 12:33 AM
neroren
Apr 29, 2010 08:26 AM
Circaskaterr
Engine Management and Tuning
Jan 1, 2010 04:29 PM
240driftkid
Mar 23, 2009 09:59 PM
all-mtr-teg
Jan 27, 2007 07:16 AM
