JRSC 94 gsr (obd1 b18c1)/problem stalling when rpms drop after giving throttle
Old Sep 22, 2009 | 10:12 AM
jcorrell1's Avatar
New User
Default JRSC 94 gsr (obd1 b18c1)/problem stalling when rpms drop after giving throttle
Its a 92 civic hatch with a JRSC gsr swap. The problem I'm having involves a bad idle and the engine stalling out. When stopped and in neutral, if I give any throttle and let off, the rpms drop and the engine either stalls out or just idles very low and almost stalls out. It also does this when moving. For instance, when coming to a stop sign or stop light.
These are all the mods
-AEM intake
-JRSC kit (stock pulley 7psi)
-255 lph walbro fuel pump
-JR fmu
-AEM fuel rail
-440 cc RC injectors
-Hondata s300 p28 ecu
-MSD 6AL ignition
-stock distributor (ignition timing set to 16)
-dc 4-2-1 headers/2.5" pipe/apexi muffler
These are all the parts I've recently replaced
-IACV
-FITV
-MAP sensor
-02 sensor
-spark plugs
-vacuum lines that came with sc kit
-coolant lines that came with sc kit
Any help will be greatly appreciated
vgsr
Jun 21, 2006 05:42 PM
prestonpark
Sep 20, 2004 05:16 PM
2K Teggy
Dec 6, 2003 03:41 PM
2K Teggy
Oct 16, 2003 06:26 PM
