Bad Caliper?
Old Sep 21, 2009 | 01:02 PM
VTEC_Viking's Avatar
Default Bad Caliper?
Ok so earlier this year I replaced the front rotors and brake pads on my 6th gen civic after believeing I had a warped rotor on the driver's side. The pad was grinded down unevenly with one side down to the metal and the other with a lot of meat still on it. The rotor was also in bad shape.
So I thought that was the problem however now after a few months of driving I've noticed that after a drive only the driver's side rim will get extremely hot. I Check all the others and will just be warm, but this one will be hot to the touch. Also tons of brake dust accumulated on this rim only coating the entire rim and caliper.
This is leading me to think that the piston in the caliper must be stuck and constantly pressing the pad on the rotor. But I dunno could it also be another reason?
I'm about to buy a new caliper assembly to put on unless someone with more knowledge steers me in a different direction. Thank you.
Old Sep 21, 2009 | 01:19 PM
delsolproblems's Avatar
Default Re: Bad Caliper?
Sounds like you have the right idea. GL
Old Sep 21, 2009 | 01:33 PM
Thanks, is this something where I should change both sides? I would rather not, but if this is implications that the other will go soon...
Old Sep 21, 2009 | 01:51 PM
I probably don't need to change the whole caliper right? Are there certain components that just need to cleaned/lubed or replaced? I found repair kits for seals around the piston.
Old Sep 21, 2009 | 01:57 PM
thumper64's Avatar
If you're replacing the seals just around the piston, just totally rebuild the caliper if you can.
Old Sep 21, 2009 | 02:03 PM
If there is a DIY online I can find probably could, doesn't seem that hard to do but I don't know the procedure yet. On a scale of 1-10, 1 being air intake, 10 being headwork how hard would you say?
Old Sep 21, 2009 | 02:48 PM
I found a good DIY thought I might post it. The procedure is fairly simple especially since I have an air compressor. It's for an Acura RSX but it's basically the same caliper.
http://forums.clubrsx.com/showthread.php?t=619048
Old Sep 21, 2009 | 09:08 PM
danomatic93's Avatar
Your caliper could be fine. Check the slide pins! Make sure that they are free moving. I had a slide pin seize on me and caused uneven pad wear and rotor warping. The cause of the seized slide pin was that the rubber boot for the pin cracked and all the grease oozed out and invited water and rust to the party.
This link is not of a Honda but it's the same idea: http://www.powerstroke.org/articles/...iew/Page1.html
usdmftw
Mar 26, 2012 04:02 PM
seer_claw
Feb 24, 2004 08:13 PM
dclub01
May 28, 2003 08:51 AM
Adampops
Aug 26, 2002 08:17 PM
Kamin
17
Mar 19, 2002 04:32 PM
