need help asap trans d series just put in no worky
I just put in a trans in my 95 hatch. I got in started the car and bled the slave. got a stiff pedal and then put car in gear (while still in the air no tires) first nothing then I realized somethin is wrong. no movement in any gear. also I can shift with the car running no clutch and it doesnt grind. wtf happened. I later realized drivers axle is out about 1/4 to 1/2" but i would thing it would grab a little with no weight and spin. what about the no grind issue...
please help just got trans after 6 months and still cant drive the car.
Push the axle in and put the car on the ground. Did you have the trans apart? Bench test it before putting it in?
need to get back out there. I put it in an put the clutch in about 7 months ago and all was fine till trans went out. put this one in and having issues. I am going to check spinning wheels and a little clutch pedal adjustment maybe that will helpl if not Im gonna have to pull it out and make sure my shift fork, throw out, and pressure plate are good, I just hope the trans is not at fault.
You say it wouldn't go into gear but when the car is on, you can shift into the gears? That's without the clutch as well with no grinding. Can you hear the shift forks moving when you shift?
average_psi
Nov 8, 2004 05:01 PM
