ARP head studs without taking off the head?
Has anyone done this? Did you experience problems later?
If I do decide to go this route, should I remove all the stock ones two at a time and replace with ARP torqued to spec or just remove all the OE ones and then use typical ARP tightening process?
i know a guy who does this with the evo's he builds...he does them one at a time...i plan on doing this with my d series soon...i talked to a guy a lil while ago and he did it this way also and he said he has not had a problem with it
not really...as long as u do it correctly its fine...you dont have to take the head off just to put head studs in...hell a lot of V8 guys put the heads on then put the studs in
if your going to all this trouble why not replace the headgasket? seems like a waste of a good opportunity. I guess if your cheap ok, but then why are you replacing the bolts with studs in the first place?
thats what i was thinking...might as well change everything right?
D16Y8-JDMYO
May 24, 2007 10:21 AM
