There Has To Be A Way For THE B20v TO WORK!!!
Old Sep 19, 2009 | 07:45 PM
b20vdelsol619's Avatar
Default There Has To Be A Way For THE B20v TO WORK!!!
Set up is a B20z block p72(gsr) head.
I recently did a valve job and currently putting the head back on.
PROBLEM: B20Z Block And Gasket are set up for the Dial Pins(Head Stud GUIDES) on the intake side.
P72 head is set up for exhaust side.
I have the lsvtec b20vtec pins that are bigger on one side and smaller on the other.
but either way it doesnt work.
This is the tricky part it came out this way but now when i put it back its not fitting correctly the pins will not fit through the head gasket.
i dont wanna drill new holes in the head on the intake side because it was working another way before
WHAT AM I DOING WRONG?
Old Sep 19, 2009 | 08:46 PM
Default Re: There Has To Be A Way For THE B20v TO WORK!!!
anyone?
Old Sep 19, 2009 | 08:56 PM
jdm_sir2's Avatar
pull the dowel out and find on what hole on the head the smaller size fits on....than take note of that, than place the bigger side on the block and see if it's going to fit on the same side....make sure the head isn't being installed with the intake side facing the front of the block...
Old Sep 20, 2009 | 12:52 AM
Corksil's Avatar
wait so the dowel pin holes on the intake side are different size than the dowel pins on the exhaust side? make sure the head isn't backwards (I know you're not that stupid..)
from there I recommend getting big dowels for the side with small dowels, then widening the holes on the headgasket for big dowels everywhere.
or just modifying the headgasket again - but that's kinda ghetto.
done fast, done cheap, done right - pick two.
Old Sep 20, 2009 | 01:34 AM
Luserkid's Avatar
http://www.goldeneaglemfg.com/index....q86fh70lv1stc6
Old Sep 20, 2009 | 02:07 AM
Corksil's Avatar
overnight shipping = $$$$
fast and right, but not cheap.
or homedepot improvised parts = cheap and fast. but not right.
Old Sep 21, 2009 | 09:39 AM
i got a drummel shaved the exhaust side of the head gasket down. Vtec kracks hard now.
Old Sep 21, 2009 | 01:03 PM
worlds-slowest-EG's Avatar
is it just me or is there a broken ex. valve in the #2 cyl in the first picture?
Old Sep 21, 2009 | 02:03 PM
Corksil's Avatar
yeah there is a broken valve.
lmao
Old Sep 21, 2009 | 07:36 PM
haha thats why i did the head but that picture is how it pulled off thats why i showed that picture. LOOKS MUCH BETTER NOW.
Old Sep 21, 2009 | 10:11 PM
it better look better now. that's all bad.
Old Sep 21, 2009 | 11:02 PM
burningrex's Avatar
lol
Old Sep 21, 2009 | 11:47 PM
K20egcw's Avatar
LMFAO @ broken valve!!
junior40er
24
Jun 21, 2006 10:52 AM
trecool44
May 24, 2006 10:07 AM
loserface
Mar 9, 2006 06:11 PM
93H22ACX
Jun 25, 2004 09:54 AM
