BDl Cam Gears and V2V questions
So I am trying to figure out my v2v but am unsure what each mark means on the BDL cam gears.
With the bolts loosened on the cam gears if I turn it left or right I can get about 3 tick marks each way. Is each tic mark a deg? On their site they say -10deg to +10 deg. Any help would be great. I am lost right now.
Also is turning to the right clockwise neg deg and left counter clockwise postive deg?
I am running skunk 2 pro 2 cams with stock size valves and what I have found so far is if I turn the inner gear to the right one tick mark and leave the other gear at zero my valves will hit. Does this sound right?
each mark on the top and bottom = 1 deg
so if the first two marks (top and bottom) are aligned thats 1 deg and if the two second marks are aligned thats 2 deg and ect...
Brewer
Feb 2, 2005 10:48 AM
