foglight install
Old Sep 19, 2009 | 02:21 PM
slo88hatch's Avatar
Default foglight install
i just installed a set of fogs on my 98 civic. lights work fine but i was wondering if that they should shut off when the high beams are on? if so how would i go about wiring them to do that? thanks
Old Sep 19, 2009 | 02:41 PM
lhd dc2's Avatar
Default Re: foglight install
The fog lights should be on its own switch and should not go off when highbeams are on. Unless you turn them off yourself.
Old Sep 19, 2009 | 03:06 PM
slo88hatch's Avatar
so do the factory foglights not go off when the high beams are turned on? a state inspector said they have to turn off when high beams are turned on. i just want to know how to do this
Old Sep 19, 2009 | 03:51 PM
jdqcivicp72's Avatar
instead of the wire being tapped into the parking lights tap into the low beam. just cut that wire from parking light connects to the relay and tap into low beam wire its usually blue wire or white... why bother doing that since its illegal to drive with high beams on. new toyotas are like that. fogs turn off when high beams are on. doesnt make sense cause if you cant see with your low beams and why turn off our fogs to use high beams. good luck with that i wouldnt bother unless its a fixaticket.
Haysie149
Honda Civic (2001 - 2005)
Aug 27, 2018 02:55 AM
honda_coupe
Apr 11, 2010 08:10 AM
civicSIfnatic
13
Aug 21, 2008 09:48 PM
PurpleAccord88
May 11, 2007 02:02 PM
J-g-D-s-M-r
Feb 11, 2004 06:19 PM
