94 sohc nvtec troubleshoot
Old Sep 19, 2009 | 11:03 AM
94Koopa's Avatar
New User
Icon6 94 sohc nvtec troubleshoot
i bought a 94 civic coupe with a d16 sohc nvtec and heres were i am on it. when i got it i put a new starter and distributor on it and it would pop like it wanted to crank and it turns over fine. we changed the ECU and after a few trys it cranked right up and after hitting the gas it died right back out and since has not even tried to act like it wanted to crank it just turns over. the fuel pump is acting wierd. when i turn the key on the fuel pump does not come on i have a hot wire run to the fuel pump so i have to let the fuel pump run for a few seconds and then try cranking it. i pulled the plugs and they had oil on the bottom so i new the head gasket was blown so im gonna change that and see what it does. i also bout new plugs... someone please help me get this car running..........
Old Sep 19, 2009 | 11:06 AM
94Koopa's Avatar
New User
Default Re: 94 sohc nvtec troubleshoot
also put a new main relay in to try and solve the fuel pump issue.. didnt help
S_F
Jul 7, 2018 03:23 AM
l1l_r1cky
Dec 28, 2012 06:51 AM
GregB
Jun 14, 2012 02:48 PM
dustyb20
Apr 29, 2011 01:00 PM
djstain
May 23, 2006 12:29 PM
