94 sohc nvtec troubleshoot
i bought a 94 civic coupe with a d16 sohc nvtec and heres were i am on it. when i got it i put a new starter and distributor on it and it would pop like it wanted to crank and it turns over fine. we changed the ECU and after a few trys it cranked right up and after hitting the gas it died right back out and since has not even tried to act like it wanted to crank it just turns over. the fuel pump is acting wierd. when i turn the key on the fuel pump does not come on i have a hot wire run to the fuel pump so i have to let the fuel pump run for a few seconds and then try cranking it. i pulled the plugs and they had oil on the bottom so i new the head gasket was blown so im gonna change that and see what it does. i also bout new plugs... someone please help me get this car running..........
GregB
06-14-2012 02:48 PM
dustyb20
04-29-2011 01:00 PM
