Broken Rear LCA Bolt HELP!!!
Old Aug 27, 2002 | 08:36 PM
_Shadow_'s Avatar
New User
Default Broken Rear LCA Bolt HELP!!!
Hey the dreaded rear LCA bolt broke when I was putting on my new suspension. What did you guys do to fix it? I used a sawzall and cut the bolt off and I got the shock out but part of the bolt is still seized inside the bushing!!! I tried using a punch and getting it out but no luck. It's in their tight. What should I do? I know this has happened to many of you. Thanks for any help
Old Aug 27, 2002 | 08:52 PM
BoM's Avatar
BoM
Default Re: Broken Rear LCA Bolt HELP!!! (_Shadow_)
remove hte arm and take it to a shop to have pressed out.
Old Aug 28, 2002 | 05:14 AM
_Shadow_'s Avatar
New User
Default Re: Broken Rear LCA Bolt HELP!!! (BoM)
Yeah that crossed my mind. I tried taking that bolt out to remove the whole thing, but it's seized also. I geuss I will have to break that one off too. Lovely
Old Aug 28, 2002 | 04:55 PM
Integra_Nguyen's Avatar
Is the arm still connected and everything? How'd you manage to get the shock out? So is it possible for you to put in the new suspension? LIke the springs? Will the car still ride with the broken bolt or will that be unsafe.
DeDonDeRosa
Mar 15, 2009 06:21 AM
civicdelsol33
Suspension & Brakes
Dec 17, 2007 09:45 AM
2Point2EH2
Apr 25, 2006 10:36 PM
thw_goalie
Suspension & Brakes
Mar 29, 2006 11:08 AM
IWearMyKswiss
Mar 15, 2004 05:16 AM
