keeping engine spot less
Wrap air filter and distributor with plastic bags. Pull spark plug wires off plugs, stick rags in the plug tubes.
Apply two cans of the Gel degreaser;
This will take any oil/grime off.
Dry the engine bay as much as you can.
Apply this liberally;
Spray it on plastic, metal, under the hood, on the engine/transmission.... basically COVER every surface of the engine bay. No wiping down, no rinsing. Makes metal/painted surfaces glossy, and hoses/plastic shiny.
I do this every other weekend... since I have no fender liners, the engine bay gets pretty dirty from daily driving... after this, the engine bay comes out sooo nice.
that what i use i today i didnt take the spark plug wire off but cover the distributor and the wire i use a shirt but that was my bad i got a lil water in the plug tubes but dry it up quick start up the motor it seem o.k. i use most of the can it still need a lil bit to be clean but it look better next time i use a plastic bag
thank
p.s anything else to check when watering off the foum
thank
Phatch99
21
Apr 9, 2004 04:31 PM
