Transmission & Drivetrain Gearboxes, Differentials, Clutches
b16j1 case wont open all of the way...
Old Sep 18, 2009 | 12:12 PM
TwotoneC1Da9's Avatar
Default b16j1 case wont open all of the way...
I took all of the necessary bolts off obviously, released the C-clamp and pried it open to about an inch and thats as far as it will go, I tried tapping the top of the case to loosen the isb bearings but still no luck...
Old Sep 18, 2009 | 10:00 PM
civickiller's Avatar
Default Re: b16j1 case wont open all of the way...
so the gear pack didnt drop when you spread the c clamp?
Old Sep 19, 2009 | 05:22 AM
nope...should i tap the bearing??
Old Sep 19, 2009 | 06:00 PM
if the c clamp is still in the bearing, open it then have somebody go with a pry bar to split the case but dont pry hard just gently and wiggle back and forth
Old Sep 19, 2009 | 06:27 PM
Mista Bone's Avatar
D Tranny Guru
did you remove reverse bolt?
Old Sep 21, 2009 | 05:01 PM
everything is A ok guys, it took some finess but it came off!
ldyer1994
Apr 23, 2015 08:19 AM
clem kevin
Mar 31, 2008 05:12 PM
wutangben
Jun 15, 2003 08:19 PM
b20guy
Mar 25, 2003 07:38 PM
IN VTEC
Aug 8, 2002 04:22 PM
