Speedometer issue
hey all, Just swapped an LS motor into a friends gsr integra, now the speedometer isn't working. The tach works, everything else works, few things I was curious about were what plugs on the back of the cluster go to what (gsr cluster still) and is it possible that the vss could be playing a role in this? I swapped his gsr motor into my del sol, with zero issues, speedo works and what not. looking for any suggestions I may be missing here.
swap the VSS from the delso and see if it works. b and d series(MT) VSS are the same. if thats not it then could be a short in a wire. was the cluster working before?
nomoreavril
10
Dec 11, 2006 04:02 PM
