Speedometer issue
Old Sep 18, 2009 | 09:28 AM
Since 1983's Avatar
Default Speedometer issue
hey all, Just swapped an LS motor into a friends gsr integra, now the speedometer isn't working. The tach works, everything else works, few things I was curious about were what plugs on the back of the cluster go to what (gsr cluster still) and is it possible that the vss could be playing a role in this? I swapped his gsr motor into my del sol, with zero issues, speedo works and what not. looking for any suggestions I may be missing here.
Old Sep 18, 2009 | 10:47 AM
hmoobhero's Avatar
Default Re: Speedometer issue
swap the VSS from the delso and see if it works. b and d series(MT) VSS are the same. if thats not it then could be a short in a wire. was the cluster working before?
Old Sep 18, 2009 | 07:46 PM
Since 1983's Avatar
the cluster was working prior, guess ill be double checking everything
TYL3R
Jun 6, 2008 10:02 AM
whitehf
May 10, 2007 08:41 PM
nomoreavril
10
Dec 11, 2006 04:02 PM
iTzKeviN
Sep 6, 2005 02:28 PM
n1neb4ll
Jan 25, 2004 01:05 PM
