zc boost
hey guys i did search no answer...
i am really thinking bout turbo my zc..i saw some pages on the web of a zc with stock internals running 12psi...i was wondering what everybody is running PSI wise i am doing a custom kit...possiable using a T3 turbo or a TD04 turbo... i want to run 13's on street tires then slicks 12's thinking bout doing JE pistons and rods..what else should i need?
if u wanna build ur own turbo u may wanna get some other stuff
i have been doing some research lately for my turbo setup
u might wanna pick up a FMU, a MSD BTM, FPR, inline pump
and have a rechipped ecu to have a nice map for ex Zdyne GOld can get u there!
also check out http://www.homemadeturbo.com i think it is.
Greedy also makes a kit. just get the 92-95 civic one and port the exuast manifold
[Modified by CR-X, 11:02 PM 8/27/2002]
hey guys i was reading that part on the turbo review on the CRX with 12lbs...i was reading bout adding in the T's for the bleed valves? is that party easy to do just tap in the the lines 3 of them then that releaves boost out so the MAP sensor doesnt think it is getting more air?
Guest
Posts: n/a
Thats my plan .....Once my ZC motor goes in... its a GReddy 92-95 kit for me with a type 24 FMIC. look for me in the coming weeks. Im running all my oil feed and return lines as well as all gauge line DURING the swap. No need to get all dirty twice
[Modified by BigDaddyRich, 7:47 PM 8/28/2002]
Boost the ZC into double digits can be a scary thing. Even with proper engine managment. The D-series Rod threshold is a bit over 200hp.. When boositng 12psi on a 137hp engine, you are getting very close to that mark. I gernaded 1 zc as soon as it hit 14psi.
I like run 9-10psi on D-series motors, they seem to like it.
Jeff Frank
Jeff Frank
hey I have a d15b7... has about 9.2 or 9.6 compression, im running all stock fuel system with a spoon chip, for a b16 in a pm6. I just want to know what u have for fuel to run 9-10 psi on the track.. also.. where is your timing at that boost .. thanks I have a homemade turbo kit. running a 87 crx with a 94 dx motor with hks mainifold to a subura turbo. intercooled and b.o.v. running 5-6 psi i have a msd and coil
[Modified by havok hybrid, 8:16 AM 8/29/2002]
My site has loads of pics of a 92-95 install on a ZC, take a look if you want
http://www.marklamond.co.uk/crx-si/turbo/turbo.htm
I am running 6-6.5 at the moment
Still got loads of work to do on the website.
AbaZ
Sep 16, 2002 07:36 PM
2nd motor i put in this one blew a rod.... so this is my 2nd zc
