no vtec
Old Sep 17, 2009 | 05:29 PM
99jdm_itr's Avatar
Default no vtec
ok so my vtec quit working on the weekend and i have n idea what it is
i changed the oil didnt work then i changed the vtec solenoid no dice
then i talked to friend he said to check the compression and the first 3 cylinders are at about 220 and the 4th is at 210 could this be the issue it burns oil in vtec (or use to) oh and its not throughing a engine code so i dont think its electrical any help is appreciated thx guys
Old Sep 19, 2009 | 01:13 AM
99jdm_itr's Avatar
Default Re: no vtec wtf
any help needed
Old Sep 19, 2009 | 01:34 AM
95DC2GS-R's Avatar
Is the sceen dirty on the 'noid gasket?
Does your speedometer work? VTEC works on speed input, oil pressure, and coolant temperature. Since you changed the oil, we can rule that out. You changed the vtec solenoid, and it still doesn't work... this leaves coolant temp, and VSS input. It's either one of the two... My buddy's Accord did this last year. The car would barely get warm, he had no vtec, and he running on limp mode. We pulled the codes and it was for the coolant temp sensor... $24 later for a new sensor, the car worked fine after that.
Old Sep 19, 2009 | 01:49 AM
racebum's Avatar
the above is very good advice. based on your compression numbers, that is NOT it. get the scan tool and verify the o2 is going into closed loop. watch the coolant temp and see what you get.
Old Sep 19, 2009 | 05:24 PM
99jdm_itr's Avatar
my temp gauge is normal and there isnt a code being thrown . the car isnt in any type of limp mode it revs smooth no bog not cut off and the speedo works fine it just doesnt hit vtec ? it started by hitting vtec for about 1500rpms then it would cut out and now it doesnt hit at all . i should also mention that i have a vafc-2 but i cant see it being that cause i havent tingkerd with the controls for it so .... maybe it could be a loose wire were it splices into the ecu harness ?
Old Sep 19, 2009 | 10:30 PM
racebum's Avatar
the vafc 2 could be wired wrong, and or you could have it set to take over vtec without setting where it actually happens. lastly you could have a loose connection somewhere. the vtec plugs is a common place
Old Sep 19, 2009 | 10:48 PM
99jdm_itr's Avatar
Default Re: no vtec
i dont think its the vafc2 its been in the car and running smoothly for a year wire could be the issue ill check it tomorrow but i was also told it could be the oil pump would the car run if it was ?
Old Sep 20, 2009 | 12:30 AM
racebum's Avatar
Default Re: no vtec
ahhh...if the oil pump is failing and oil psi is low, yes this could be a problem. very hard on rings and bearings as well. also double check the vafc settings, you may just bypass its vtec function and see if it comes back if other solutions do not work. vtec is fairly simple to troubleshoot. it's also possible the solenoid or oil switch on it failed, they do from time to time.
Old Sep 20, 2009 | 07:10 AM
99jdm_itr's Avatar
Default Re: no vtec
how would you check oil pump ?
Old Sep 20, 2009 | 01:12 PM
racebum's Avatar
Default Re: no vtec
you would need to rig up some way to check oil psi, also you want to check coolant temp at the ecu, not the gauge. if you don't have a scan tool these are screaming deals right now. this model has a live data feed that monitors ecu function live. even closed loop a/f
http://www.amazon.com/Actron-CP9145-...3480332&sr=8-1
Old Sep 20, 2009 | 09:16 PM
99jdm_itr's Avatar
Default Re: no vtec
i have a scan tool i just never scaned it cause it isnt throwing a code maybe i will scan it then
Old Oct 29, 2009 | 09:31 PM
luispizarro25's Avatar
Default Re: no vtec
so whats up anything going on here... issues resolved...
bump for you...
Old Nov 1, 2009 | 12:01 PM
99jdm_itr's Avatar
Default Re: no vtec
nothing no one can give me a legit issue i think its that the compresion is to low i dont know
amaidendevil
May 16, 2016 01:24 PM
Chpwhtek
Mar 19, 2012 04:48 PM
seldon
May 30, 2009 05:24 PM
iCONxEG21
Nov 22, 2007 11:00 PM
tallguy
15
Mar 29, 2005 10:36 PM
