Master Clutch Cylinder- Canada Model
Old Sep 17, 2009 | 11:04 AM
craigttnelson's Avatar
Icon2 Master Clutch Cylinder- Canada Model
This should be an easy one for somebody. I want to replace the master clutch cylinder on my 98 civic. It was built in Canada. The only master cylinder available at advance auto said models "except canada". The staff didn't know anything about it. Are they refering to cars sold in canada as candian models or ones built there. The cylinder looks just like the one I have in the car now. Lots of parts website don't mention anything about origin of the car etc. What is the best way to keep it all straight and to always get the right parts?
Old Sep 17, 2009 | 04:00 PM
94EG8's Avatar
Seagull Management
Default Re: Master Clutch Cylinder- Canada Model
all '96 - '00 civic master cylinders should be the same, actually '92 - '95 civic and '94 - '01 Integra should be identical as well. I don't know why their info would say that. You should be safe with whatever you order.
Old Sep 17, 2009 | 05:02 PM
Deetz's Avatar
Crazy Honda Guy
Originally Posted by 94EG8
all '96 - '00 civic master cylinders should be the same.
Is this true, i thought the 99-00 EM1 had a larger master cylinder?? Correct me if i'm wrong,
Old Sep 17, 2009 | 05:09 PM
Blurkey's Avatar
I have run into problems with the clutch masters on that generation civic. The flair nut that threads into the master comes in two different sizes. If I remenber correctly one has a nut for a 10mm wrench and the other is 12mm. The size of the hole the pipe goes into is reflected in the sixe of the fitting. Big hole big fitting, Small hole small fitting.
Old Sep 18, 2009 | 03:44 AM
Thanks everyone for the information. Basically it seems to come down to either it fits or it doesn't.
Mugen112
Jul 16, 2009 07:14 PM
Hyoriu
Apr 16, 2009 09:10 AM
airsodam
May 22, 2006 11:07 PM
B18CJDM
Mar 15, 2002 07:28 PM
