d15b2 tranny vs d16a6 tranny
im swaping in a d16z6 and wondering how much better would the d16a6 tranny be? i can get one but its gonna cost me 350 buks which is more then i paid for the d16z6 lol....... what do you think the quarter mile difference would be between the two trannys? thanks.
Hmm... i use a hybrid tranny so i can't really lend any insight on how different they "feel".
I do know that on paper, they are not much different and $350 is a ridiculous price.
Unless your goal is to make an all out track car, Id just go with the DX tranny.
well the a6 tranny has shorter ratio's but quick response shifting in to gear and the b2 just has longer ratio's slower response into going in gear because i started off with a b2 tranny then a a6 tranny so i know the difference but i recommend go with a a6 tranny
the a6 is a great tranny to have, but its not worth $350. not unless its in like prisitine condition inside and out. also, the gears are not shorter between the lx/dx/si trans. it's only the final drive that changes.
oh yea thank for corrrecting me its the final drive that changes hahha
thank you for explaining haha Reminds me that I need to find a Si final drive and get a LSD for my tranny still
WTF? the speed in which a tranny shifts has nothing to do with it being Si or DX. Its the trannys condition that will have an effect on "shifting response".
Ok, you are thinking about this wrong. If you have a RWD background then the Final Drive in a FWD transmission would be the ring gear / differential gear in the RWD setup.
Basic torque flow:
Input --> Selected Gear (1-5/6/7 application dependent) --> Final Drive / Ring Gear / Differential Gear (application dependent) --> Wheels on the road go round and round...
http://videos.howstuffworks.com/hows...work-video.htm
ahh ok ok got ya.....so my dx at 60 mph or 100km sits at about 3k rpm what would the si tranny with the 4.25 final drive rev at going the same speed?
Thx for the help guys
Also is there any numbers on the si tranny so you can differentiate it from a dx?
used a tranny calculator which said at 60mph the dx trans would be at 2758 rpm, Si trans would be at 3015 rpm. will vary slightly depending on rim/tire size.
http://www.zealautowerks.com/transcalc.php
yes. although the rpm difference at a given speed isn't much, the si tranny is much quicker. the dx tranny has a higher top speed, but the si trans with the higher fd allows you to get to that slightly lower top speed much quicker. the higher the theoretical top speed, the longer its going to take to accelerate to it. when you factor in road friction and wind drag you realize it's nearly impossible to hit that theoretical top speed anyway.
nd8ch
16
Mar 19, 2004 10:54 PM
SuicideSlide
Jul 19, 2003 12:37 PM
