Twin Disk Clutch stop questions
im bout to make a clutch stop for my car. debating how to make it. welding a nut or to drill a hole with two nuts. do you guys have any pictures of your clutch stop set up. Also my car doesnt start if the clutch isnt all the way in so i need to by pass this safety feature. i also dont know whether i want to use full throttle shift. what do you guys recommend
What you can do is replace the clutch swith with a nut and bolt (if you dont use it) and make that the clutch stop. My buddy did that to his car. I'm about to do that today on my car.
Adriano
Adriano
I welded a piece of angle iron to my clutch petal with a welded nut to the iron. Put a bolt through it with a nut so you can adjust it as needed.
dustinbs144
Feb 8, 2012 11:53 AM
