Moroso Disconnect Switch and ZERO gauge
So I've relocated the battery to the back of the car using a "0" gauge wire, and need to install a disconnect switch. I've been looking at the Moroso 74102 and the 74101 but was wondering if I can even connect such a HUGE gauge wire to the bolts on the back of the disconnect switch.
Anyone have experience as to whether it will fit...
Thanks.
Thanks.
I forgot the model number I have but it does look lik the one above except for the pin coming out!
the back of my switch does have large studs for the bigger ring terminals.
The one you have is probably the Moroso 74101. What gauge wire were you using? I just need to make sure that it'll fit because a 0 gauge is pretty darn big when compared to the 4 gauge wires...
I ended going a different route, but get the ring terminal from moroso or taylor!
just get the corresponding ring terminals for the wire and switch!
0 g is not that big compared to the aut(sp) ****.
left hand side of that page next to the battery terminal! thats what I used! with some heat shrink and your good to go!
Ebay would be your best bet, but if your around the norwalk area then Team C performance will have it.
Orangewebdev
Jun 23, 2016 01:44 PM
avilarmando
Jul 11, 2015 04:55 AM
74101, 74102, add, b16dragyahoo, battery, disconnect, disconnects, gauge, kill, moroso, ring, switch, terminals, versus, wire
