LC-1 and wideband and narrowband output..
Alright so I have an LC-1 with a gauge as well, I have read that you can have them both setup, but you must switch between the narrowband and the wideband to use the LC-1 as both.
However in the instructions it says you must use analog 2 for the gauge so it can read correctly.
My question is how can I setup my LC-1 so that it can read off my gauge in narrowband and wideband mode when ever I decide to switch between the two.
Also is there a way I can I wire it so that I will be able to switch between the two in s300 by changing the voltages?
So to recap..what I am trying to do is to be able to use my gauge in both narrow and wideband mode. Also if possible to find a way to switch between the two modes in s300 by changing something.
If anyone has done this before I would apperciate if they share how they have done so.
Thanks again!
Thanks again!
Re: LC-1 and wideband and narrowband output..
go to www.innovatemotorsports.com and check out the forums or ask in there. they awnsered all my questions about my lc1 and lm2.
Orangewebdev
06-23-2016 01:44 PM
Pelican
12-10-2003 08:16 AM
