Old Mar 31, 2015, 12:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Honda Accord Interior Guides
Print Wikipost
installing aftermarket sub in 2008 civic SI
Old Sep 16, 2009 | 03:49 PM
sportyolds's Avatar
Default installing aftermarket sub in 2008 civic SI
I knowww there are threads somewheres. But i cant find the exact help I need.
I am just installing a JL 12 in. and a mono amp into my 4 door civis SI (w/out navi).
I bouight the amp converter kit from best buy that I need so I don't have to get a remote signal from behind the front dash.
I have the power run easily, the ground, and the amp hooked up to the sub fine.
I am not sure exactly what wires to connect underneath the rear dash to the amp converter. This then plus into the amp. But what about the actual remote imput on the amp?
epic failure on my part.
Old Sep 16, 2009 | 04:51 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: installing aftermarket sub in 2008 civic SI
What part did you by from best buy that gives you a remote turn on. Please give me a part number
Old Sep 16, 2009 | 05:58 PM
jason0123's Avatar
there are a few LOC's out there that will give you remote turn on output. There is a 12v input, a ground, and they are signal sensing. So when they sence audio they trigger the remote output.
wire colors should be.
blue- remote turn on
yellow- 12v constant
black- ground
white-left positive input
white/black-left negative input
grey-right positive input
grey/black-right negative input
RCA-audio output
Old Sep 18, 2009 | 06:34 AM
sportyolds's Avatar
Thanksss. I don't have the part # but I got it workin! So now I have everything ran, and tested. Except I didn't run the power wire yet underneath the front dash into the engine bay. Is there an obvious hole I can squeeze it through? Maybe near the cluth or somethin?
Old Sep 18, 2009 | 07:43 AM
chawski's Avatar
i think there are a few pop-outs in the firewall, but honestly, its just easier to drill a small hole. I ran my amp cables through the same hole i ran my fog light switch and just sealed it off with some silicone. never had any leakage problems
Old Sep 18, 2009 | 08:49 AM
sportyolds's Avatar
Ok thanks. I'll pull back the firewall around the clutch and see if I find anything. I don't have a power drill, so I may end up just having to go buy one. heh.
Don't ya hate leakage? lol
Old Sep 18, 2009 | 08:59 AM
mrdeadman's Avatar
They let me pick
If you drill your firewall make sure to put something between the bare sheet metal and the wire so the wire shielding doesn't get sliced up and start arcing and catch your car on fire.
Old Sep 23, 2009 | 11:34 AM
chawski's Avatar
yea i just used silicone (maybe polyurethane window glue...not sure, it was a long time ago). As far as Ive seen, as long as you use plenty of it, the wire should be plenty protected.
haha gata love the leakage
Old Sep 25, 2009 | 12:15 AM
98civdx's Avatar
Master Detailer
try to find a empty groument, or something before you drill your firewall.
Old Sep 26, 2009 | 10:27 PM
XstreamRocker's Avatar
Just make sure that when you run your wires under the hood that they don't touch any parts of the exhaust and cant get pinched in the steering or suspension.
cormac42
Audio / Security / Video
Jun 19, 2017 02:40 AM
hoosiers15
Jan 24, 2007 10:07 PM
JdM_RACeR07
Nov 19, 2006 04:02 PM
Arsenal
Mar 9, 2004 07:06 PM
intenseEK
23
Dec 17, 2003 06:54 PM
