Shaking Steering wheel is Driving me NUTS!
I dont know why its been happening lately. When I seem to get on the freeway at around 65mph the steering wheel starts to shake really bad like the lug nuts are loose or something but I double checked that already. It never did this before. Tires and Rims are brand new and are already balanced, I got an alignment already, and even rotated the tires. What could it be? the axels? loose motor mounts? My ride is at stock height but slightly an inch lower.
It also makes a weird clunking sound and I can actually feel the vibration of the clunk on my left foot when I set it down on the foot rest or when I'm holding down on the clutch. I have no power steering either so it vibrates like hell at around 65+mph
Specs: Skunk2 full coilovers, stock camber kits on front but not rear. Extended studs and 205/50/15" rims falken ziex. H2b motor 97 Civic Hatch
Have they wheels been re balanced since you noticed the vibration? Could have lost a wheel weight.
How are the shocks? A bad shock will exaggerate a problem.
What about ball joints and tie rod ends?
What about the ball joints and tie rod ends? I also checked those when I removed my wheels. Seems like they are in place and are locked with a safety clip. Could it be my wheel bearing? Oh God I hope not
An wheel bearing will make more of a humming noise then shaking of the steering wheel. Does it happen during breaking or just cruising? if braking it could also be the brakes.
How you check the ball joints and tie rod ends
Ball joints- visually check them make sure they have jelly in them, and are not all ripped up, or cant be moved with out a little bit of force.
Tie Rod ends check to see if either broken right off or again if they can be turned or moved easy without mush force
mine was doing that and i looked at the inside of my front right tire and there was a huge bulge poping out. when you run on a tire that doesnt have enough air you can get one of those.
Im gona lean towards needing the wheels rebalanced. Did it start after you rotated the wheels? If it did, im willing to bet my dogs left nut that the shop never balanced one of your rear wheels. Otherwise, maybe a weight fell off, or one of your wheels are bent
Can someone explain to me a clunking noise that happens around 65mph? I start feeling it on my left foot and even on the clutch when i press it down.. its starting to scare me more and more each time.
Also my car has alot of torque, so everytime I shift gears at around 3,4krpms, it sounds as though the motor is shifting or moving around like theres a loose mount or something.. I checked many times and even had to retighten some motor mounts just in case and it still does the same thing..
i'm assuming aftermarket wheels..?
you can balance them all day long but if you don't use an pilot adapter then you're wheel will never really be centered on the hub. make sure you pick up a set if you don't have them already, then rebalance and see if that helps.
Depending on if they have been replaced before, you may have to buy the hole upper control arm. If its still doing this after you get it done. I would look at the tires. My old hatch had brand new ziex's put on them and the day after, the body said that the outside belt jumped the outher belt. It looked wierd and hardly noticable
Upper ball joint or lower? If it's the upper ball joint, you have to replace the entire A arm assemble, which is around $128, dealer cost. Lower ball joints are cheaper, but a PITA to install. I just installed roll-center adjusters on my coupe the other day, and it took about three hours for both sides, most of that spent pressing them in.
The ball joint just hammers out with a few good whacks, should be a straight-forward install with a ball-joint press. I had to use a vice and other tools for my roll centers because they're machined to a much tighter tolerance to be a much tighter fit. you should have no problems. Suggested labor is 1.8 hours, but maybe you can get a hookup or do it yourself.
If it's the lower ball joint just take it to a shop for them to replace it. It's too much of a PITA to do yourself unless of course you have a ball joint press. It will take them around an hour to do, if you try to do it yourself you could spend all day doing it depending on your skill and tools.
You can rent the tools from Autozone. Be sure to get the supplement set for Hondas along with the basic ball joint removal/installation kit. It took me less than a half hour to remove and press the new ball joint. Most of that time is to try figure out which pieces of the kit to use. Probably around the same time (30 mins) to pull everything off to expose the ball joint.
raidacaipo
19
Jul 14, 2009 07:30 PM
MBlake55
Jun 18, 2005 08:27 PM
Weapon_R
Feb 25, 2005 11:09 PM
raene
28
Feb 13, 2004 12:08 PM
