Suspension & Brakes Theory, alignment, spring rates....
HOw to calculate Spring rate....
Old Sep 16, 2009 | 11:14 AM
src810's Avatar
Default HOw to calculate Spring rate....
saw this on another forum might be usefull.. sorry if this thread was already posted before...
Thought this migt be useful to you guys.
The spring rate = (1406250 x d x d x d x d) / (N x D x D x D)
d = wire diameter in inches
N = Number of active coils.
The flattened coils at the ends are not considered active.
D = Mean diameter of spring.
Half way between the inside & outside diameter.
I've tried it for a few odd springs and it generally comes within 10% of what the manufacturer reckons it's supposed to be.
Old Sep 16, 2009 | 01:21 PM
TunerN00b's Avatar
Default Re: HOw to calculate Spring rate....
Such calculations only work when comparing different springs made out of the same alloy. It lacks a variable to account for material used.
Old Sep 18, 2009 | 01:27 PM
Bailhatch's Avatar
I use a rate tester.
Old Sep 20, 2009 | 05:09 AM
batallic's Avatar
or u can use this http://hondaswap.com/reference-mater...n-chart-30786/
Old Sep 20, 2009 | 06:50 AM
Bailhatch's Avatar
Originally Posted by batallic
That is a conversion chart. That won't help you if you have an unknown spring in your hands.
Old Sep 23, 2009 | 09:43 AM
therealtime's Avatar
How many springs are made out of alloys that aren't steel? The modulus of rigidity is the same within a fraction of a percent for every common steel alloy that springs are made of.
Here are a list of steel properties if you're interested: http://www.engineersedge.com/manufac...s_strength.htm
Modulus of Rigidity "G" is the same as Modulus of Elasticity in Shear which is shown in the table.
The spring rate equation with all variables is k=(G*d^4)/(8*n*D^3)
where k is the spring rate, G is the modulus of rigidity, d is the wire diameter, n is the number of active coils, and D is the average diameter (inside diameter plus wire diameter).
Given that G is about 11.4 million psi for steel alloys, that reduces the equation to:
k=(1425000*d^4)/(n*D^3), which is about 1.4% different than what the OP stated.
I'd say they were pretty close. This equation is good if you dont have a rate tester, but the tester that Bailhatch mentioned would be the most accurate in all cases (unless the force or length gauge on the rate tester is out of calibration).
-Tony
Old Sep 23, 2009 | 12:20 PM
TunerN00b's Avatar
http://www.hypercoils.com/Suspension...Advantage.aspx
Originally Posted by hypercoil.com
What’s more, Hyperco manufactures from materials that are not found in a mill’s standard inventory. This allows our engineers to design suspension coils to optimum specifications with the largest variety of wire diameters available today. We also manufacture from a wide variety of materials including ultra high tensile chrome silicon, micro alloys, titanium, alloy steels and stainless.
How common it is to use non-standard materials for springs for cars, I can't say, but it is something that needs to be considered if trying to calculate spring rate based only off of external dimensions.
Old Sep 23, 2009 | 02:36 PM
This is why I gave the actual equation, which includes "G". The equation can only be simplified as shown if the material is assumed to be affordable steel.
Nice job with the citation, but if I had the money for titanium suspension parts, I wouldn't be modifying a Honda.
Sean @ ESG
Suspension & Brakes
Nov 23, 2005 01:22 PM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
96 SOHC VTEC
Mar 30, 2003 10:17 AM
Superhatch
10
Feb 8, 2002 06:59 PM
B18CXr
Dec 12, 2001 12:59 PM
