Surface rust on cylinder walls question
So i have this motor that i left sitting in a car with two cylinders full of antifreeze and oil mixture for about six months, and as a result i have some surface rust on my cylinder walls. i am able to clean it up with an sos pad, and it doesn't seem to leave any scratch marks on the hone job. i need to know if i should get a hone job or just clean up the rust and run it as is.
thanks to any and all that can help.
I wouldn't have used an SOS pad but if you got it off there should not be a problem. Having light rust or mild surface rust is fine if you can clean it off. If there is any pitting you should get the motor re-honed. Since you posted no pictures and we are just speculating, if you are worried get it honed and if the hone throws it out of service limit get it bored...
t0p_sh0tta
May 22, 2007 07:32 PM
spork motorsports
14
Apr 24, 2007 07:39 AM
