Opinions needed: Evaluate my Oil Drain Line.
Old Sep 15, 2009 | 02:50 PM
dez6's Avatar
Default Opinions needed: Evaluate my Oil Drain Line.
The area surrounded in red is what I am concerned about. The angle of the center section be completely straight up and down? Or is the current position where it is slightly canted towards the block ok? I have it set like this due to the fact that the ends of the fittings are off center of each other otherwise.
Another angle.
Old Sep 15, 2009 | 03:43 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Opinions needed: Evaluate my Oil Drain Line.
Don't worry it is fine. You don't have to have it perfectly up and down just as long as it is not at something extreme like the return facing the hood latch or the hood for that matter LOL...
Old Sep 15, 2009 | 03:55 PM
esedulerp5tenin's Avatar
almost perfect. dont worry bout it.
Old Sep 15, 2009 | 04:20 PM
SOHC_MShue's Avatar
looks great to me.
Old Sep 15, 2009 | 10:18 PM
kcjohnnyboy's Avatar
looks fine to me also
Old Sep 15, 2009 | 10:46 PM
91jdmhatchback's Avatar
Originally Posted by SOHC_MShue
looks great to me.
i will add looks better then 90% of the returns out there.
Old Sep 16, 2009 | 12:17 AM
AbitAvenger's Avatar
Old Sep 16, 2009 | 11:26 AM
civic_r87111's Avatar
Garrett along with every other turbo manufacturer I know recommends anything under 35* is optimal for a gravity oil return.
Old Sep 16, 2009 | 11:32 AM
accord_raffi's Avatar
that's as vertical as you can get it on that setup. looks fine
Old Sep 16, 2009 | 12:24 PM
Bailhatch's Avatar
mint
Old Sep 16, 2009 | 12:52 PM
Bseriescivic5's Avatar
looks good man, I had to actually get a 45 degree bend on mine, looks just like yours, Should be good to go
ExVtec
Mar 16, 2011 12:32 AM
Flexin5
Apr 11, 2007 10:23 AM
SM00TH976
Jun 6, 2006 10:48 AM
gnar kill
Sep 28, 2005 03:55 PM
PrecisionH23a
Sep 16, 2003 04:21 AM
