changed water pump now car has less pull
ok i changed my water pump last night, and after i got it back together and took it for a drive it has 50% of the power it had before.......can some one please help????
pull off your covers and crank pulley put it on #1 tdc more than likely your cam pulley will be off a little, take the timing belt off roll your cam to where the "UP" mark is directly up
pull your timing belt from the crank to the cam pulley, use a 12MM wrench and roll the cam towards the front of the car a hair put the belt on all the pulleys and the tensioner, after the belt is on roll your cam back towards the car, but be careful not to roll the crank with it, then you let your tensioner spring back, take a small screw driver or small prybar and pry on the tensioner using the crank pulley as a pivot point, you want less than a 1/4 inch play in the belt
do this and let us know how it feels afterwards
wk9k
Mar 13, 2012 05:45 PM
sukcak
Jul 17, 2008 07:45 AM
