178whp is this about right?
Old Sep 15, 2009 | 02:07 AM
turboeagle4g63's Avatar
Default 178whp is this about right?
my friend has a gsr block 12.2cr pistons b16 head with crower 2 3/4 cams springs retainers type r intake manifold and throttle body edelbrock 4-2-1 headers 2.5 exhaust car was tuned with 93 pump crome 12.9 -13.0 af/r on a dynojet car made 178whp at 7800rpm the power started to fall after that but after 8000rpm the power fell really bad rev limiter 8500 vtec 4200 vtec was set low because it was making more power than the low cam from 4000 and up
Old Sep 15, 2009 | 02:55 AM
Meister vtec's Avatar
Default Re: 178whp is this about right?
it would have made an extra 35 hp if you had a pissing kid sticker,an aem sticker and a giant wing oh and painting the car a neon colour adds another 40hp just my 2 cents!
buddy one of the major rules here are theres no bench racing/hp guessing but if you ask me that does sound low for all that work if there really is such a thing hence alot of people here are e-builders,but if soo what kind of dyno and was it sae corrected?
Old Sep 15, 2009 | 02:51 PM
95skunkedgsr's Avatar
are u able to post the dyno graph to look at it
Old Sep 15, 2009 | 02:54 PM
DDTECH's Avatar
178whp, is a number, take it to the track and see what it runs.
Old Sep 15, 2009 | 05:15 PM
gearhead16's Avatar
did you try setting vtec higher? i have those cams in my b16a and my vtec kicks at 6000
Old Sep 16, 2009 | 12:46 AM
anothersickhatch's Avatar
we need a graph and a little more information on the build. if you need help or suggestions, we need more.
Old Sep 16, 2009 | 09:06 AM
newtron63h's Avatar
vtec being set low shouldnt affect top end cuz it will still be engaged at high rpm. the b16 head could possibly be an issue, being designed for 1.6L flow, it could run out of air at high rpm since its trying to flow more air. id look at the map and airflow readings during the run. also are the injectors big enough?
Old Sep 16, 2009 | 09:13 AM
Garage 808 Hatch's Avatar
Sounds like the cams need dialed in. That setup should make peak power near 8.5krpm IMO
Old Sep 16, 2009 | 12:16 PM
newtron63h's Avatar
i like this thought,
does it have adjustable cam gears?
4k sounds WAY too low for vtec to be helping especially with those mods, if the cams are off, the power band could be moved lower in the rpm range.......thus running out of power at high rpm.
being able to see the graph would help.
Old Sep 16, 2009 | 02:54 PM
I had Crower 3 cams in my 11.5:1 B16. really simple setup, 68mm TB, AEBS cheap *** IM, DC 4-2-1 header. Cams dialed in to card specs, made peak HP at 9300 rpm.
Old Sep 16, 2009 | 03:27 PM
Chef Andre's Avatar
HT's TOP CHEF
Power does sound low with the mods. Post a graph please.
Old Sep 16, 2009 | 04:03 PM
TheMightySi's Avatar
Whats the compression on all cylinders? I had a similar issue with an LSvtec build it made 172hp a week later it did 193hp turns out the rings did not seal all the way. Oh and what rings you using?
Old Sep 16, 2009 | 05:09 PM
boxeocampeon's Avatar
it does sound low
92 hatchback
Jun 8, 2009 06:05 PM
diggy
Dec 22, 2007 02:04 PM
CeeJayy
Feb 25, 2007 11:22 AM
slodel
Apr 16, 2004 01:04 AM
JDM CRX
Mar 4, 2003 02:13 PM
