tps adjustment?
Are you Seriouse???? ^ C'mon man??
Our Hondas base so much on the TPS sensor setting bieng correct.
You need an OHM meter. Now you must take both leads of the ohm meter to the lower 2 pins on the TPS and look for a value of .500-.900.
Looking from the top.
Place one Lead on each bottom 2 pin's (you have a total of 3)
you should recieve a reading on your OHM meter.
you must adjust the TPS untill you are within spec. Kinda like a Distributor.
At exactly 5:07 Goes into the TPS Adjustment
Witchhead Charles Madrid is the Man!!
http://www.youtube.com/watch?v=ukPoe5E4Fqg
okay ya!. i got my ohm meter. but for some reason the tps i have on right now only has one screw that has a slit grinded into it. the other screw doesnt even look like theres a head on it. i dont know how to explain it. But its obviously been replaced so theres gotta be a way to get it off. i cant really even see it because its on the bottom. Do i need to take off my whole throttle body to do this? because i really dont want to have to do that.
polything
23
Jul 27, 2012 08:23 AM
nutball72
Nov 11, 2006 07:14 PM
