H22a civic EGR code 12.... argg
Old Sep 14, 2009 | 12:41 PM
butter99's Avatar
Default H22a civic EGR code 12.... argg
So my 95 h22a civic hatchback has an egr code # 12
I have gone through the service manual a good 10 times just find out I should replace my failed ECU ((: I have not substituted a known good ecu.
the ports in the intake manifold are clean..When I take the egr valve off and turn on the engine a lot of exhaust comes out of the exhaust port and I have major sucking vacuum power in the vacuum/intake port.
I am really starting to flip out cuz I can't find the answer no matter how long I work on it.
The only components in the code 12 system are the EGR valve, EGR solenoid and vacuum diaghram, some hoses, and wire to the ecu. WHY THEN CAN"T I FIGURE IT OUT!!?
Old Sep 14, 2009 | 12:49 PM
n0rmaL's Avatar
Default Re: H22a civic EGR code 12.... argg
using a stock p13?
Old Sep 14, 2009 | 12:59 PM
butter99's Avatar
yes I am using a stock usdm p13
Old Sep 16, 2009 | 05:07 PM
jshaw23's Avatar
Did the swap that you put into your car come with everything need for the egr system. If all you have is the egr valve itself than that is your problem, i have an h22 in my ek and all i have is the egr valve and i always get the code 12. There is nothing that can be done unless you use p28/hondata s300 and you can turn any sensors off that you want. Hope i helped.
snowblind7x
Jan 28, 2010 07:37 AM
saaron34
Jun 15, 2006 04:00 AM
civic2.2
Sep 29, 2005 01:41 PM
diewX3
Jan 26, 2005 09:22 AM
blackdelslo
Apr 16, 2004 02:31 AM
