front lower control arm bushing mount, civic 93
Old Sep 14, 2009 | 10:42 AM
nightrider's Avatar
Default front lower control arm bushing mount, civic 93
I am replacing all bushings on my 93 Civic Si.
Honda only sells the bushing including the mount, which is $70 too much per side and ebay has some OE replacements for $40 per side, but I'd rather stick to OEM bushings.
Honda lists the part #s as 51396 SR0 A02 and 51395 SR0 A02. Is there a part for just the bushings to be pressed into the mount for the front lower arm?
Old Sep 14, 2009 | 11:34 AM
nightrider's Avatar
Default Re: front lower control arm bushing mount, civic 93
Energy Suspension sells this bushing, but I could only find it a part of their master kit.
http://www.energysuspension.com/asse.../pdf/17141.PDF
The circled bushing that goes into the circled bracket is what I'm talking about in the in pdf above. Any help? Called Honda, but they said I have to buy the whole bracket, which I don't entirely believe.
Old Sep 14, 2009 | 12:23 PM
nightrider's Avatar
made a few phone calls and they are called the front compliance bushings.
anyone know where to get OE replacement ones? Energy and Mugen only have poly...
Old Sep 14, 2009 | 12:47 PM
94EG8's Avatar
Seagull Management
You can't get just the bushing on its own. You should be able to find good used ones at a junkyard though. The compliance bushings usually stay pretty good, its the other 2 that normally go bad. Hardrace also sells the compliance bushings, they aren't poly IIRC, but a harder rubber than stock.
Old Sep 14, 2009 | 02:49 PM
nightrider's Avatar
thanks, i need to stay away from poly based on the research i uncovered today.
i think i'm going to have to suck it up and buy the compliance bushing oem new. i figure if i'm replacing everything else anyway, do it only once.
DavidR
101
Jul 6, 2009 09:22 PM
1.5Slowmatic
Suspension & Brakes
Feb 16, 2009 07:17 PM
Eyal 951
Feb 9, 2007 01:06 PM
Trickturn
Suspension & Brakes
Sep 13, 2006 04:48 AM
GSRoadRage
Sep 1, 2001 11:18 AM
