Eurthane trailing arm bushings?
Anyone here have experience with the eurethane trailing arm bushings? and how hard are those things to change? I have all the other bushings in eurethane, but these just came out and I was thinking of adding these to my suspension collection. Thanks...
Re: Eurthane trailing arm bushings? (GSRoadRage)
I put in my mugen trailing arm bushings last week. It's not terrible hard, but it's a pain that's for sure. You gotta unbolt the lower and upper arms, the abs wheel senor bracket, the lower shock mount, and the a couple of bolts at the front of the arm. After you take off the arm, you have to take it to a machine shop to have the old ones pressed out and new ones pressed in. It's pretty hard to find a place, although if you try going to a place that specializes in suspension that might be easier.
As for any differences I can't say because I replaced my shocks at the same time. My bushings were cracking so I wanted to replace them, but if yours aren't that old it's hard to say if you should.
I've been thinking of swapping my stockers out for a URETHANE set. What was the cost to have the bushing pressed in?
Re: Eurthane trailing arm bushings? (Big Ed)
It cost me 20 dollars for both arms. In other words 10 dollars a bushing.
If you are in So. Cal I highly recommend Bear Frame Suspension and Wheel.
Thanks everyone. Looks like I'll be getting them and then having Bymar Tire and Brake install them for me. They did all the other eurethane bushings on my car.
