b16 rods in z6
Old Sep 14, 2009 | 10:09 AM
umair's Avatar
Default b16 rods in z6
im planning to build a z6 for boost and i got vitara pistons. i want to go with b16 rods but i was just wondering what i have to do to make the rods fit in a z6 block??
thanks
Old Sep 14, 2009 | 10:47 AM
Ruben19's Avatar
Default Re: b16 rods in z6
i don't think this will work
Old Sep 14, 2009 | 10:59 AM
umair's Avatar
i know it will work...b16 rods in a z6 has been done before.
Old Sep 14, 2009 | 11:09 AM
hondamark35's Avatar
thanks
list diminsions for each: length, wrist pin dia., crank journal dia., bearing width... then you'll see what needs to be modified to make it work.
Old Sep 15, 2009 | 12:59 PM
:::SIRll_EJ1:::'s Avatar
it will work but it will be a biaaatch. i know someone who tried this and didnt have the proper rod-crank clearance and one of the rods snapped and shot through the block.
best of luck.
Old Sep 16, 2009 | 05:42 AM
Furyof4's Avatar
It will work if you mill down the big end, make a bushing for the small end, and don't care that the piston will be 3mm in the hole. Will the availability of $200 forged rods there is absolutely no reason to do it.
Old Sep 16, 2009 | 06:19 AM
92civiceg9gsr's Avatar
The r/s ratio goes down from 1.52 to 1.49 if you use B16 rods. You could use B18a/b rods tho. BTW I just googled this in 30 seconds.
clomonolo
Engine Machining & Assembly
Apr 27, 2016 09:23 AM
SLOSI7
Feb 18, 2010 02:16 PM
xxiong88
Feb 17, 2008 07:10 PM
The Stance
Mar 22, 2006 12:29 PM
nerdsports
Jul 21, 2003 05:15 PM
