96 civc (d16y8) squeaking
Looking for some help?? i got a 96 civic with a d16y8 and am having this horrible squeaking sound coming form around my timing belt and alternator. I know that is not my alternator or my power steering because i have removed the belts and it still does it. I changed my water pump and timing belt pulley thinking that was the problem but still nothing. right after i changed the parts i got it back together and it seamed to be good. i let it sit and get to running temp and no sound. I drove it about 15 mile and turned it of when i come back out i started it up and the squeaking was back. i notice that when i have a load on the motor the squeak goes way. but when i let off form accelerating it comes back. any help would be great thanks!!!
Timing belt tension is too tight so the tensioner is screaming from too much load. loosen up the timing belt a lil bit and it should go away. Seen it happen quite a few times.
CALC!_JUST_du_IT!
Jun 10, 2008 12:55 PM
Andy099
Sep 19, 2005 11:28 AM
