Tire rotation
Old Sep 13, 2009 | 05:25 PM
globy123's Avatar
Default Tire rotation
Hi. I have a 99 Honda Civic Sedan and I was wondering what is the recommended factory method of rotating tires? I don't have an Owner's manual to look it up.
Old Sep 13, 2009 | 07:06 PM
David12's Avatar
Default Re: Tire rotation
theres 2 different ways you can rotate them. either fronts to back or criss cross fronts to back
Old Sep 13, 2009 | 07:08 PM
P_Dink's Avatar
Sedans FTW! lol
I have a 98' civic sedan and work at a tire company. It is recommended to rotate your tires every 3-4k miles ( Every oil change). IF your tires are directional then you can ONLY rotate front to rear, but if they are just a normal tread IMO i would rotate... L/F to R/R; R/F to L/R; and just rotate both rear tires straight up front L/R to L/F and R/R to R/F
I hope this helps
98civdx's Avatar
Master Detailer
also depends on your tires
are the directonal? or not? if not what he said will work fine.
Old Sep 13, 2009 | 07:31 PM
kjou2001's Avatar
New User
It used to be commn to criss-cross your tires, but now you only move from front to back or vice versa on the same side
KJ
Old Sep 14, 2009 | 06:25 AM
globy123's Avatar
Originally Posted by P_Dink
Sedans FTW! lol
I hope this helps
How do I check whether the tires are directional? I bought them in 2004 and they are made by Firestone.
Old Sep 14, 2009 | 06:27 AM
grumblemarc's Avatar
The Grumpiest
By the pattern on the tread mostly. Some, if not most or all, actually have an arrow on the sidewalls that tells you. I haven't committed that detail to memory though.
Old Sep 14, 2009 | 07:25 AM
alphalanos's Avatar
KJ
wat. op there should be some marking on the tire if its directional. for example it might say "outside" or have an arrow integrated into the sidewall. post up the model of tire and we can prob look it up.
Old Sep 14, 2009 | 11:17 AM
globy123's Avatar
Sedans FTW! lol
I hope this helps
I have the Firestone FR680 02 tires. Are these directional tires or can I criss-cross them when I rotate the tires?
Old Sep 14, 2009 | 12:34 PM
eros18's Avatar
check the threads of the tires
if they all point to one direction like an arrow ^ or \\\, you can rotate front to rear ONLY
for example (lol) you can do cross rotation
if the threads are like the ones below, front to rear rotate ONLY
if anything seems wrong with the explanation i made, please correct me.
Old Jun 23, 2020 | 12:11 AM
Gordon Freeman's Avatar
Proper rotation for regular tires is cris-cross the rears to front and fronts go straight back.(RR>LF,LR>RF,RF>RR,LF>LR) Directional tires have arrows on them showing their rotation direction and they go front to back back to front. This info comes from the Civic owners Manual.
https://www.manualslib.com/manual/71....html?page=316
Old Jun 24, 2020 | 06:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
If the tires are bald/ worn from camber wear don't move them to the front replace it! Some shops sell used tires if you want to go that rout they usually have like at least 75% and go for like $40 installed depending on the shop.
PatrickGSR94
Mar 11, 2013 05:12 AM
vtecsi00
May 27, 2008 11:12 PM
Squad1
Honda Motorcycles
28
May 20, 2007 08:37 PM
teg969
Mar 21, 2006 01:19 PM
RogerYung
May 12, 2003 10:15 AM
