vtec sometimes WTF?
Old Sep 13, 2009 | 04:48 PM
98 ek hatch's Avatar
Default vtec sometimes WTF?
OK H-T here goes
Old setup
91 CRX hf obd0 LSVTEC
ran the car last year NO problems
New setup
exact same long block
JDM P30 ecu
Rywire harness/OBD1 conversion Brand new O2 and Dizzy
Brand new RC 310cc injectors (yea no resistor box)
AN-R compact header (open header right now)
Wire tuck
92 GSR trans
Problem
I have a problem with vtec. I have to let the car warm up to the point the cooling fan comes on, for vtec to activate...So If i go like 50 mph for 2-3 miles I have to let it warm up again so it activates vtec. Its like it cools down to much for vtec to activate.
Put in a new 180 degree thermostat ( thinking the spring was weak or it was stuck open) NOPE
No Cel lights (hold the two wires together and it lights up constant)
Im wondering if OBD0 and OBD1 have different temperature sensors???
Does the P30 have a higher temp for vtec to activate????
Is it possible having solid mounts and open header tripping the knock sensor??? (no cel for it though)
Im not a newb I had to re-register for some reason. I know vtec is working when its warm enough cuz it just about rips the header off the head.LOL
THANKS FOR ALL THE HELP
Old Sep 13, 2009 | 04:53 PM
ryanevansoh's Avatar
Default Re: vtec sometimes WTF?
more info if you want help
Old Sep 13, 2009 | 04:56 PM
mother ef-er's Avatar
Originally Posted by 98 ek hatch
jfhfjgfjugty
is this a joke?
.. just let your motor warm up. vtec isnt cold weather friendly.
Old Sep 13, 2009 | 05:22 PM
apekd's Avatar
hmmmmm.....I gots not a single clue on this one.
Old Sep 13, 2009 | 05:36 PM
Sorry guys I was having computer trouble. My question is now posted.
Old Sep 13, 2009 | 05:40 PM
Crx Jimmy's Avatar
the ecu uses a different sensor to read the temp than the gauge , my guess is that one is failing and not reading right. try replacing it.
Old Sep 14, 2009 | 03:44 AM
OK I will test. Anyone else have this happen before?
Old Sep 14, 2009 | 09:57 AM
anybody have any more ideas?
Old Sep 14, 2009 | 10:45 AM
staticchmbr's Avatar
mine doesnt kick in until its warm..check the sensor like above. other than that, make sure your oil isnt low
Old Sep 14, 2009 | 07:33 PM
Hmmm still havent figured it out yet!!???
Old Sep 15, 2009 | 07:23 AM
Old Sep 15, 2009 | 06:28 PM
lsvtecef08's Avatar
i know some people will look down on v-cons (vtec controller) but it will make vtec come in if the motor is bone cold or low in oil.. it will hit either way.. and u can adjust it or just get a simple rpm activated switch and run that to your vtec solenoid?
olskoo_Dude
Feb 3, 2012 10:26 PM
Db1_77
Sep 1, 2007 12:19 PM
twin-turbo
Oct 25, 2005 10:24 AM
flat-blk-HB
16
Sep 30, 2002 07:04 PM
OneB16
May 22, 2002 01:36 AM
