HELP! THROWING CODES 3 & 41 - ENGINE BOGGING BARELY STARTING ETC!!!
Old Sep 13, 2009 | 04:15 PM
gotboosthatch's Avatar
Default HELP! THROWING CODES 3 & 41 - ENGINE BOGGING BARELY STARTING ETC!!!
hey guys, i have my bseries vtec swap in my 97 civic..
I rewired everything like your supposed too like iat, iacv, etc..ive done many swaps before.
I have a obd2>obd1 jumper harness in the car, p28 chipped ecu..
Im throwing codes 3 and 41.. Map sensor and primary o2 sensor..
The car will barely stay running even if it does stay running and idles all messed up and bogs and stutters. Ive changed map sensors twice with 2 good ones and its still doing it.
Any ideas of what the problem could be?
Thanks in advance! Let me know thanks
Old Sep 13, 2009 | 04:42 PM
Default Re: HELP! THROWING CODES 3 & 41 - ENGINE BOGGING BARELY STARTING ETC!!!
Old Sep 13, 2009 | 05:35 PM
anyone?
Old Sep 14, 2009 | 03:57 PM
help?
Old Sep 15, 2009 | 10:13 AM
anyone????????
Old Sep 15, 2009 | 10:16 AM
rick_rabies's Avatar
I'm not Rick!
if youv many swaps before...give us more info
what obd is the motor?
do you have the correct obd dizzy?
why did you rewire the iat?
is the map sensor getting any signal?
do you have the tps and map switched?
Old Sep 15, 2009 | 11:34 AM
obd1
yes correct dizzy .. using obd1 with obd2>obd1 dizzy jumper harness
rewired iat cuz it has the sensor on the intake mani runner
how do I check if the map is gettin signal? a volt meter?
tried tps and map switching back and forth still have problem
Old Sep 15, 2009 | 11:39 AM
I'm not Rick!
use a volt meter. pull the pins out of the sensor 1 at a time and check them.
1 should get signal
1 should get powa
1 should get ground.
trace the wires also. map sensor will make the car act real syco
Old Sep 15, 2009 | 04:43 PM
ighttt
Spoon-ITR-
Mar 12, 2007 11:09 PM
dek1mfk
Nov 7, 2006 07:39 AM
zCivic
10
Mar 27, 2006 06:59 PM
JdmIntegra98
May 19, 2004 11:51 AM
