OBD0 B16 Distributor, converted to grey plug OBD1?
Old Sep 13, 2009 | 06:30 AM
sirtef9's Avatar
Default OBD0 B16 Distributor, converted to grey plug OBD1?
I searched but didn't get a good answer. Can I just re-pin my OBD0 distributor and put on the Grey Plugs instead? Looks like there would be No reason why I can't but figured I'd ask in case someone knows something I don't.
TIA.
Old Sep 13, 2009 | 06:40 AM
Foowee's Avatar
Default Re: OBD0 B16 Distributor, converted to grey plug OBD1?
No there is a reluctor wheel inside that has teeth on it. 0bd0 has a different number compared to obd1/2. Obd2 dizzy's can be repinned to work w/obd1 and vise versa. obd0 is different.
Old Sep 13, 2009 | 06:44 AM
sirtef9's Avatar
Theres no way to use that relucter wheel in with the OBD0? I have the parts but if I can't I can't. Thanks for the qwick reply.
Old Sep 13, 2009 | 12:58 PM
zrickety's Avatar
you need the obd1 distributor, end of story. you can repin the plug on the car's harness if you want
Old Sep 13, 2009 | 05:33 PM
sirtef9's Avatar
Thanks for the info. New distributor on the way:-)
6doorsentra
Feb 11, 2007 06:57 PM
ej8
Jan 27, 2005 10:56 PM
Ruby Civic
Nov 27, 2004 06:00 PM
DA-MAX
May 16, 2004 01:44 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
