high power alternator?
Old Sep 12, 2009 | 10:28 PM
gabe768's Avatar
Icon2 high power alternator?
my teg's battery got completely dead, it read a 0.09 volts, because of my subs
i was wanting to get a high power alternator, and was wondering if
a)this is a legitimate high power alternator
b)if this is enough amps to run my subs (2 10's, a 600 watt amp)
thanks for the help
http://cgi.ebay.com/ebaymotors/Acura...Q5fAccessories
Old Sep 12, 2009 | 10:35 PM
mrdeadman's Avatar
They let me pick
Default Re: high power alternator?
How old is your battery?
You do not need a ho alternator if you are only pushing 600watts ( you probably listed the max output anyway, so the RMS value is less.)
Your battery probably just gave up the ghost.
Test your alternator by running the multimeter across the battery when the car is running (given your battery is good) it should read ~14.4 volts.
Old Sep 12, 2009 | 10:51 PM
Ruben19's Avatar
first of all, you will need a capacitor and a new battery then test your alternator to see if is good
Old Sep 13, 2009 | 12:05 AM
MHDesigns's Avatar
Just get a power cap. a 1fared cap will do better than fine for 600watts.
Old Sep 13, 2009 | 01:51 AM
95DC2GS-R's Avatar
Better grounds and power wires will help more than a capacitor. Upgrade your ground wire from frame to engine, ground from battery to frame, power from alternator to battery, etc.
On 600 "watts" a stock electrical system is more than enough. I was drawing almost 130amps on a stock '97 Civic EX alternator with 0/1 wire for my power and grounds, granted I had two Kinetik HC800's in the back but still.
Aftermarket alts for our cars a so much money, and not worth it. As I recall, the stock one is around 70amps, and the biggest I've seen in a while is only around 100amps.
Old Sep 14, 2009 | 08:44 AM
gabe768's Avatar
i took it into autozone (because i had a durlast) and they replaced it for me for free so i have a brand new battery...
but on certain songs, with my amp disconnected, my head unit screen flickers and dims really bad which is what it did when my battery was dying
Old Sep 14, 2009 | 10:34 AM
mrdeadman's Avatar
They let me pick
Check your grounds.
Old Apr 22, 2020 | 12:45 PM
Bart Sproles's Avatar
I have a 95imp 1000watt sub amp with max for mid and heights. My back up battery is not charging. But my front is what wrong
Akavietboy201
Feb 10, 2010 12:34 AM
h92
Audio / Security / Video
Mar 18, 2004 06:59 PM
daver
Sep 19, 2003 10:39 PM
97excoupe
Feb 27, 2002 12:01 PM
Christine
Jan 23, 2002 06:17 AM
