how to build to 10k rpm?
Old Sep 12, 2009 | 06:29 PM
4 door beast's Avatar
Default how to build to 10k rpm?
i need to know everything thats neccesary to do to build my gsr for 10k rpms right now ive got it tuned for 9k with b16 head ctr pistons let me know how cani build it strong enough for 10k?
Old Sep 12, 2009 | 06:38 PM
esco115's Avatar
Default Re: how to build to 10k rpm?
well for starters ur going to need springs and retainers along with valves, before u start dropping those bitch's along with a set of cams...
Old Sep 12, 2009 | 06:49 PM
-__-'s Avatar
yup and like ARP head and rod bolts. polished/balanced crank? and the spoon block guard brace lol
Old Sep 12, 2009 | 06:53 PM
ok how much would a full engine balance run me? i hear that helps with vibrations during high rpms?
Old Sep 12, 2009 | 08:54 PM
RedDC2GSR's Avatar
reving to 10k is only required if your are building power past 10k. With a mildly buld engine I'd be supprised if you were making power past 8500-9000. You may want to have it dyno'd and see what the power curve looks like. If you don't have any drop off past your current redline then go ahead with the race spec vavle springs and retainers. but don't waste money to be able to rev your engine 1000 rpms past your power curve.
Old Sep 12, 2009 | 10:05 PM
Ruben19's Avatar
no need to rev to 10k if you want to be fast.
go turbo
Old Sep 12, 2009 | 10:20 PM
DC206R's Avatar
go turbo
X2
Old Sep 12, 2009 | 11:15 PM
omiehomie's Avatar
Originally Posted by DC206R
X2
x100! NA power is by no means in any shape, way, or form CHEAP...
Old Sep 13, 2009 | 01:54 AM
95DC2GS-R's Avatar
No reason to spin that high, because I'll take a bet you're not going to sink enough money into that motor to make the power to need to rev that high.
What are your plans for your car, what's the current setup, how much power do you want and how much money to do you have to spend?
Old Sep 13, 2009 | 05:35 AM
IN VTEC's Avatar
How about 10k + turbo?
KartelB
18
May 8, 2009 03:35 PM
integranator
Jan 11, 2007 05:14 PM
JadeGreenEF9
Oct 19, 2006 09:45 AM
SuedeB
Feb 16, 2005 12:01 PM
mdj_ge
Oct 8, 2004 12:02 AM
