Civic that has no 1500-3000 rpm..
Old Sep 12, 2009 | 05:01 PM
lsturboguy's Avatar
Default Civic that has no 1500-3000 rpm..
i just got this EG.. its got a Y7 with a z6 or b7 intake manifold in a DX body.. its running stock dizzy, stock p06, throwing 14 and 1 codes.. i put a new o2 and 1 went away.. i also replaced the iacv from code 14 and its still showing that code.. plus it drives like ****..oh and a new tb as well!! so new tps and map
it idles at 100 rpm, it bounces at 1500 when you give it light throttle input and it skips right to 3200 when you give it a little more.. the only way to see anything between 1500 and 3000 is to put load and drive it.. oh and if you try to cruise at 1500 with light throttle input, it bucks and shakes like crazyy!! its almost impossible to drive at like 30-40 mph.. unless you put it in 4th and give it like half throttle.. whats the deal!!!
Type 56
Nov 3, 2022 08:56 AM
ejoner
Oct 23, 2007 08:03 PM
CarnEvil
Jul 3, 2007 04:36 PM
Mach69
May 16, 2005 07:02 PM
