car has bad idle
Old Sep 12, 2009 | 03:04 PM
lrcrx90's Avatar
Default car has bad idle
my friends car has a bad idle when you turn on the car the rpm go up to 2000 and then start to go up and down on its own what could cause this?
Old Sep 12, 2009 | 07:21 PM
gqstatus05's Avatar
Default Re: car has bad idle
IACV. Idle Air Control Valve may need to be cleaned. You could also try to bleed the air out of his radiator or it could be a air leak somewhere. I would start with cleaning the IACV.
I almost forgot... we need to know which car your friend has.
Old Sep 12, 2009 | 08:10 PM
CG6Accord8o1's Avatar
iacv or dirty butteryfly on the tb
Old Sep 12, 2009 | 09:20 PM
BlackZ's Avatar
New User
I actually have the same problem, but i have no idea where the iacv is. any pics?
Old Sep 12, 2009 | 09:28 PM
garagejunkie's Avatar
I have had this problem for a long time..and have done a lot of research about it. This link here has a lot of really good info. http://www.askmehelpdesk.com/cars-tr...le-177846.html
My guess would be your IACV, take it off, clean it..or just buy a new one. You can get them off ebay for like $45-50. Also check the fast thermo idle valve, its attached by a hose to the IACV. It also could be your throttle position sensor. Check for vacuum leaks! Good luck.
Old Sep 12, 2009 | 09:29 PM
Google it.
Old Sep 13, 2009 | 02:33 PM
ShadowWorkssimc's Avatar
Its on the front of the intake manifold, its not hard to find, just follow the 12m water hoses that warm it , it should have a Denso label on it as well.
Old Sep 13, 2009 | 03:45 PM
IACV is located on the intake plenum, to the right and just below the throttle body, i attached a pic of the iacv. Once you see the pic you can easily identify it.
Old Sep 13, 2009 | 03:50 PM
There is a fast idle control valve to the right of the IACV in the picture, that can do with a clean using some carb cleaner.
Quick question guys, Should the engine stall once you cover the main throttle body with you palm? mines does not stall at all and I can't figure out how its turning over?
Old Sep 13, 2009 | 05:00 PM
I second cleaning the Fast idle valve..
Good question, i was just working on my car today and i closed the throttle all the way and it cut out. I also was working on my dad's log splitter which uses a carb. It would only run with the choke on. Whenever we opened the throttle, it would die; pretty much the opposite effect. We then took the entire thing apart, cleaned it, and it worked again. Seems like your car is running rich..
Old Sep 17, 2009 | 05:50 PM
miller9779's Avatar
you gotta get a new one. they're expensive as ****.
Old Nov 4, 2009 | 12:27 PM
Gho$t's Avatar
I have a DA with a B16A swap and the idle started jumping from 1000 to 2500+ rpm and I cleaned the IACV and its still doing it, what should I try next?
Old Nov 4, 2009 | 02:40 PM
HonBeer's Avatar
**** is expensive? You must be a youngin talking like that
Old Nov 4, 2009 | 04:14 PM
nus_dogg's Avatar
Fast Thermo Idle Valve(FITV)!! Located under the Throttle Body.
Both my F & H does it right after the swap, so I went ahead and screw back down the wax ball inside. Problem fixed!
Old Aug 22, 2010 | 01:17 PM
honda_sanchez21's Avatar
I have the same problem. I have changed the iac valve actually there is two of them the one on the pic above and to the right of that one there is a cylinder looking one too. they are your iac valves also known as your idle air control valves, but that might not be he problem your problem might be your throttle position sensor because that right now is my best guess for mine. if you un plug the sensor on the back of your throttle body it should stay accelerated to about 4000 rpms and should not fluctuate up and down if it does that we have found our problem
Old Aug 22, 2010 | 02:05 PM
joe_accord23's Avatar
i use to have this problem, its the IACV. take it out and clean it using carb cleaner, i did this and my idle went away, only that my idle was low not bouncing, do this and u should have cleared the problem..its a big change! good luck!!
Old Aug 22, 2010 | 02:11 PM
to complete the cleaning steps, n since u already have the carb cleaner, clean the throttle body.
Old Aug 22, 2010 | 02:12 PM
wut car does this IACV belong to?, i noticed the difference in the positioning of the hosing.
Old Aug 22, 2010 | 02:16 PM
clean the other FIV!! if it continues its the throttle body sensor, or u may need to renew the IACV and FIV!
self_made
Apr 10, 2021 02:25 AM
TearSDMF89dx
Jan 3, 2012 04:31 AM
BrokenRex
Oct 13, 2005 08:25 PM
Carpediem291
Mar 22, 2004 01:44 PM
s2k
Feb 25, 2003 06:50 PM
